Funnel Chart
A funnel chart consists of a series of trapezoids stacked from top to bottom. Each section represents a stage in a sequential process, with the size of each section indicating the volume difference from the previous stage. Funnel charts are ideal for visualizing drop-offs in business processes such as recruitment, sales pipelines, or approval flows.
Below is an example of how to create a funnel chart.
Example: Track Monthly Recruitment Progress​
Data Scope: Filter records in the “Recruitment Tracking” worksheet where the “Date” is within the current month.
Dimension: Use a non-numeric field (e.g., Stage) to group records.
Value: Select a numeric field (e.g., number of records or a custom numeric field). The value determines the size of each stage in the funnel.
Chart Configuration​
1. Create a New Chart​
2. Set the Data Scope​
Filter the Recruitment Tracking worksheet to include only records from the current month.
You can also add additional filters as needed.
3. Select Chart Type: Funnel​
Dimension: Select the "Stage" field
Value: Select the "Candidate Count" field (aggregated as Sum)
4. Funnel Orientation​
You can choose between vertical and horizontal display layouts.
Additional Settings​
In the Style section, you can:
  1. Enable or disable conversion rate display
  2. Enable comparison with previous month/year
If no additional configuration is needed, simply click Save to apply your settings.
