World Map
1. Overview​
A World Map Chart is used to visualize data distribution across global or regional maps.
It maps geographic locations (countries/regions/provinces) to coordinates, bubble size to represent a numerical metric (e.g., order volume or profit), and bubble color to differentiate by category (e.g., agent type). This chart is ideal for visualizing global agent distribution, regional performance, or market intensity.
🌍 World map charts are available in the Ultimate Edition only, and are not visible in other editions.
2. Use Cases​
  • View order volume and profit distribution across countries for the current month
  • Analyze global activity by different agent types
  • Compare regional market performance to support sales and marketing strategies
3. Chart Configuration​
Select Data Source​
Choose the target worksheet and record scope from the Data Source section.
Select Chart Type​
Choose the World Map chart type.
Chart Settings​
SettingField TypeDescription & Recommendation
Region (Dimension)Geographic fieldSelect Region (Country) or switch to province/city as needed
ValueNumeric fieldKey metric to display, such as Order Volume or Sales
Point SizeNumeric fieldControls bubble radius, e.g., Order Profit
Color (Category)Categorical fieldDistinguishes categories like Agent Type
FilterFilter conditionLimit by time range, country, agent type, etc.
Bubble position: Based on country/region coordinates
Bubble size: Indicates metric scale (larger = higher value)
Bubble color: Represents categorical dimension (e.g., agent type)
💡 The "Value" and "Point Size" fields must not be the same.
If your goal is to show sales amount by region and use that value for bubble size, consider creating a calculated field, such as: Calculated Field = Sales Amount + 0
Then, assign this calculated field to Point Size in chart configuration.
