Word Cloud
A word cloud visualizes a collection of words in a cloud-like graphical format, often used to display the frequency or prominence of keywords within large volumes of text data.
Below is an example of how to create a word cloud chart.
Data Scope: Major selections submitted this year
View: "All"
Time: This year
Word Label (Dimension): "Major"
Word Size (Metric): A numeric field in the worksheet (e.g., number of records), which determines the visual size of each word
Chart Configuration​
1. Create a New Chart​
2. Define Record Filter​
Filter records in the "Academic Statistics" worksheet where the “Creation Time” is within the current year.
You may also add additional filters if needed.
3. Select Chart Type: Word Cloud​
Word Label: Select the "Major" field
Word Size: Select the "Number of People" field (aggregated using Sum)
4. Word Cloud Style​
You can choose between rectangular or elliptical layout styles.
Click “Save” to complete your chart configuration.
