Templates Management
1. Entrance to create a template
2. Rename/Delete a template
3. Edit a template
For system printing templates, you just need to re-check the fields that need or don't need to be printed and save them.
For templates in Word format, click [Edit] and upload the newly designed Word file.
4. Available scope of templates
Sometimes, the printing templates do not need to be displayed in every view, so you can set a available scope.
By default, the template is available when printing records in all views. You can set the views in which the template is available by clicking [Usable for].
