Control - Region/City
When managing business entities, it is often necessary to specify their geographic location—such as an employee's place of birth or a customer's company location.
The Region/City field supports multi-level location selection worldwide, enabling efficient data entry, accurate filtering, and visualized analysis.
1. Basic Configuration​
Selection Scope​
There are two configuration options for the selectable region scope:
Specified Region:
Users can only choose from a predefined list of regions.
Global:
Users can select from all global regions.
If the selected country/region is China, three levels of location selection are supported: Province, Province-City, Province-City-District/County.
If the selected country/region is not China, two levels are supported:
State/Province, City/County.
Selection Required to the Final Level​
  • If the Region/City field is configured as Province-City, users must select a city before they can save the record.
  • If the field is configured as Province- City-District/County, users must select a district/county to proceed with saving.
User Selection Interface
Administrative Division Charts use data from this Region/City field for visualization and analysis. Currently, this chart supports statistics for China only.
2. Writing Rules​
The Region/City field supports data input via Excel import, API, and workflow.
  • For Specified Region Types
    When the region is set to China, the imported data does not need to include the country name — only province, city, and district/county are required.
    1. The platform first checks the hierarchy configuration of the Region/City field (e.g., Province-City-County).Data will only be written if it matches the configured structure.
    2. The format must be complete and use “/” as the delimiter between levels.
      All levels must be included — e.g., Henan Province/Zhoukou City/Fugou County.
      If the imported data is just Henan/Zhengzhou, it will not be written.
    3. The hierarchy must be accurate. For example, Henan Province/Qingdao City is invalid and will be rejected.
    4. For China’s four municipalities, use the format City/District directly — e.g., Beijing City/Chaoyang District.
  • For Global Types
    The imported content must begin with the country name.
Example
Suppose you want to import Henan Province/Zhoukou City/Fugou County — The system will behave differently based on the field's configuration:
  • If the field is set to Province only, it will search for and match Henan Province. If matched, the data is written.
  • If set to Province-City, it will check whether Zhoukou City exists under Henan Province.
    If yes, the data is written. If not, the data is skipped.
See the example below for more details:
Tips: Handling Separate Province / City / County Fields
In some cases, external systems (e.g., via Webhook) may provide region data in separate fields — such as one for province, one for city, and one for district.
To handle this:
  • Use a workflow to concatenate these values into a single string.
  • Write the concatenated value into the Region/City field.
