Control - Department
The Department control allows you to select departments configured within the organization. It also supports automatically filling in the current user’s department. Both single-select and multi-select modes are supported.
Field Configuration​
1. Selection Mode: Single / Multiple​
  • Single select: Only one department can be selected
  • Multi-select: Multiple departments can be selected
You can switch the selection mode after saving the field configuration.
When using multi-select, you can drag selected departments to adjust their display order.
2. Selection Scope​
You can restrict which departments are available for selection. Four configuration options are supported:
  • All: All departments in the organization are selectable
  • Specified Departments Only:
    You can select:
    • A fixed department or a department field
    • A member field
    When a member field is used as the scope, it represents all departments that the selected members belong to.
  • Specified Departments and All Sub-departments:
    Includes the selected departments and all their sub-departments
  • Sub-departments Only:
    Excludes the selected departments and includes only their sub-departments
3. Permissions and Scope​
Permissions for Members in Selected Departments​
You can assign roles to members within the selected departments:
  • Member: Members of the selected departments are added as record members (joiners)
  • Owner: Members of the selected departments are assigned the same permissions as the record owner
  • None (Data only): The department field acts like a text field and only stores department data
Being assigned as a member or owner does not guarantee access to the record. Permissions still depend on role settings.
Learn more
Scope (Which Members Receive Permissions)​
  • Members of the selected department only
  • Members of the selected department and all sub-departments
    • Example: If “Sales Department” is selected, members of its sub-departments will also be granted permissions
  • Department managers of the selected department
  • Department managers of the selected department and all parent departments
4. Default Value​
You can configure default values for the department field:
  • Set a fixed department (applies to all users)
  • Reference another department field in the current worksheet
  • Reference a department field from another worksheet
5. Display Department Hierarchy and Deleted Status​
  • Show department path:
    When enabled, if the selected department has parent departments, the full hierarchy path will be displayed.
    When disabled, only the department name is shown.
  • Show deleted:
    By default, deleted departments appear as empty.
    When enabled, deleted departments will be displayed as “Deleted”.
6. Department Management​
Learn more
